Known issues with Android OS built by Emteria on Raspberry Pi 3B/B+ (RPi3)
Known issues
WiFi online issue
Android OS built by Emteria only can use WiFi online, if you synchronize the time with the internet. Because the Raspberry Pi 3 does not have a real-time clock you need to synchronize the time manually each time you start your RP3 after a while.
To do so, follow these simple steps:
  1. Access the Settings menu.
    rpi3-settings-marked
  2. Scroll down to System (depending on which version you use, you might have to look for General).
    Select the Date & Time option.
    rpi3-settings-date-time-marked
  3. Set the date yourself via Set date.
    rpi3-settings-date-marked
  4. Select the date format of your choice.
  5. Set the time yourself via Set time.
    rpi3-settings-time-marked
  6. Select the time of your choice.
  7. Leave the Date and Time option.
