Known issues with emteria.OS installer
emteria.OS installer for Windows
Error message: error in mz_zip_reader_extract_to_callback
On some combinations of SD cards and SD card readers the emteria.OS installer cannot write the raw data and runs into the forementioned error. Sometimes it helps to reconnect the SD card and restart the installer and try again. If the error persists try to completely format the SD card and restart Windows. If possible, you can also try a different SD card or SD card reader. As a last resort you can use the emteria.OS installer for Linux on a live Ubuntu DVD / USB stick.
