How to find Raspberry Pi settings with Android 11
With Android 11 our custom Raspberry Pi Settings are hidden deep in the system settings, but in five short steps you can get there.
  1. On your device, enter the App Drawer by swiping from the bottom up on the home screen.
  2. Open Settings.
  3. Navigate to System.
  4. Expand the Advanced options.
    Note: If you ever happen to delete your Emteria Settings shortcut; it can also be found here.
  5. Click on Raspberry Pi to enter our RPi4 settings.
    Note: Here you can change the default audio channel, your favorite resolution, and the underlying kernel mode.
