How to create a group (Beta)
Note: The new Devices overview is at the moment a Beta feature. Beta features are experimental and can be toggled on and off in your Settings.
We value your feedback about the Beta features at info@emteria.com.
  1. Log in to your Device Hub.
  2. Enable the beta features in Profile > Settings.
  3. Navigate to Devices.
    header-devices-marked
  4. Select the Subscription wherein you want to create a new Group.
    Create-group-beta-marked
  5. On the Subscription Level Card click on the three dots in the top right corner.
    Create-group-beta-1-marked
  6. Enter a Name and a Description and click CONFIRM.
    Create-group-beta-6
  7. You can find the New Group under your Subscription.
    Create-group-beta-4-marked
  8. You can now proceed to moving licenses into your new Group.
