Known issues with Android OS built by Emteria for the RockPi 4 Model B
To install Android OS built by Emteria on the RockPi 4 Model B follow our RockPi Installation Tutorial.
Known issues with Android OS built by Emteria for the Rock Pi 4 Model B
Low resolution / pixelated graphics
You can change the resolution in System > Display > expand Advanced > HDMI > Resolution.
DSI Display
The Rock Pi offers different images for DSI and HDMI displays. Our Android image for the Rock Pi is based on the HDMI image, therefore DSI displays like the official RPI touchscreen do not work. There are no plans to support DSI displays as the DSI image is based on Android 7.
3.5mm Audio Jack
No audio via audio jack. It is a known issue for that board, not Emteria specific.
Bluetooth reconnect
Enabling Bluetooth initially works, but disabling and re-enabling crashes.
CSI cameras
CSI cameras are not supported.
Emteria provisioning / universal license
Provisioning is currently not supported.
Missing anything? Let us know in our forum!
Past issues with Android OS built by Emteria for the Rock Pi 4 Model B
OTA Updates - fixed in v11.0.70
It was not possible to install OTA updates. Previous versions must re-flash the eMMC.
