Configuration through system properties for Raspberry Pi
The Emteria Raspberry Pi builds contain several possibilities to configure the system through system properties.
These properties can be set through the console with the following command:
setprop <property name> <value>
See our article on how to access the console: UART.
Setting system properties is also possible through our provisioning system or our MDM.
The following table holds property names, values and results.
| Property name | Property value | Description |
| persist.rpi.vc4.force | kms | Forces the system to use Raspberry Pi’s KMS. |
| persist.rpi.vc4.force | fkms | Forces the system to use Raspberry Pi’s Firmware KMS. |
| persist.rpi.mode.force | <width>x<hight>@<refresh_rate> | Forces a user-selected resolution if the selected resolution is valid and supported. If the user enters an unsupported resolution the system selects 1920×1080@60 as default. |
| persist.rpi.cmdline | cmdline=<commands> | Extends the kernel command line given by <commands> several commands are separated by spaces. eg. cmdline=androidboot.product.board=emteria |
| persist.rpi.mode.connector.index | 1 | Only for RPi3 Forces the system to use the HDMI connector. |
| persist.rpi.mode.connector.index | 2 | Only for RPi3 Forces the system to use the DSI connector. |
| persist.rpi.audio.output | <card_number>:<device_number> | Only for RPi3 Forces the system to use a specified audio card and device. default: 0:0 (HDMI) |
| persist.rpi.audio.card | <card_number> | Only for RPi4 Forces the system to use a specified audio card. default: 0 |
| persist.rpi.audio.device | <device_number> | Only for RPi4 Forces the system to use a specified audio device. default: 0 (HDMI) Set it to 1 for audio jack. |
| persist.rpi.display.allow.disconnect | 0 (default) | Only for RPi4 Primary display is not disconnectable. |
| persist.rpi.display.allow.disconnect | 1 | Only for RPi4 (beta) Primary display is disconnectable. |
