Introduction to System options in Emteria Settings
This article gives an explanation of System options in Emteria Settings on your device.
Article overview
Installed version
Check for updates
Update settings
Shutdown actions
Used NTP server
Submit bugreport
Introduction
In your Emteria Settings, under System options you will find all useful information about your version of Android OS built by Emteria, you can check for and set updates, manage the reboot options and more.
Installed version
This tab displays the current version of Android installed on your device.
system-options-installed-version
Check for updates
This tab opens the update application to check for available updates.
system-options-check-updates
update-check-for-updates
Read our tutorial on how to manually update your device.
Update settings
Enable and configure the updates for your device.system-options-update-settings
update-check-automatically
Shutdown actions
Manage the Shutdown app here.system-options-shutdown-actions
You can toggle to enable and disable Recovery, Reboot and Shutdown.
shutdown-app-options
reboot-enabled-all
Use-case:
When in Kiosk Mode you can configure the Shutdown app to only have the Reboot option if you don't want users to have access to the Recovery mode or to be able to completely shutdown the device.
reboot-enabledreboot-enabled-eg
Read our tutorial on how to configure the Shutdown App.
Used NTP server
system-options-NTP
Add the URL to the NTP server and click OK.
system-options-add-NTP
Submit bugreport
Here you can send the latest system logs to Emteria to help debugging.
system-options-bugreport
Add a detailed description of the problem and how it can be reproduced.
When you're done, click SUBMIT.
Read more about submitting bugreports in the how to log and report bugs article.
