How to enable Kiosk Mode through Device Provisioning
This article explains how to enable and set up apps for Kiosk Mode through Device Provisioning in the Emteria Hub.
Note: Enabling Kiosk Mode and setting apps for Kiosk Mode through Device Provisioning is done as part of the pre-configuration process of your devices. Changing provisioning options does not affect the configuration on already installed devices. Of course, enabling and disabling Kiosk Mode can also be done through Commands or directly on your device.
Read the following tutorials on:
- Log in to the Emteria Hub.
- Navigate to Provisioning.
- Choose existing provisioning settings or create a new one.
- Scroll down to Application Preferences.
- To enable Kiosk Mode fill in the following values:
Package name: com.emteria.kiosk
Category name: com.emteria.kiosk_preferences
Preference type: bool
Key name: prefs_kiosk_enabled_key
Preference value: true - Click Add.
Note: For further explanation read an Introduction to Device Provisioning.
How to set apps for Kiosk Mode
Under Application Preferences fill in the following values:
Category name: com.emteria. kiosk_preferences
Preference type: set
Key name: prefs_allowed_apps
Preference value: com.example.packagename,com.example.secondpackage
Note: What to keep in mind when filling in the Preference value:
- Only package names are needed,
- Package names are separated by a comma (,).
